[mapguide-users] [ZS1] Re: MS SQL and SDF Join Problem
anakando anakando at yahoo.com
Fri Sep 12 03:34:00 EDT 2008
Thanks for suggestion. I afraid i cannot change id data type to integer since
it contains both of integer and char such as 'FLAG 010'..i just wondering if
this is related to the space between 'FLAG' and '010'??
Try linking the tables with integer columns, that is usually the only
stable solution.
Regards, Kenneth Skovhede, GEOGRAF A/S
anakando skrev:
> Yes..my MG version is 2.0.1..Here is my situation. I have database that
> contain 2 tables (as example). Both of tables are linked to SDF file
View this message in context: http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19450975.html
