[mapguide-users] [ZS1] Re: [ZS1] Re: MS SQL and SDF Join Problem
anakando
anakando at yahoo.com
Fri Sep 12 04:12:23 EDT 2008
This is definitely what i am thinking to do now. But i dare not to modify
these database(at least for now)even change it data type since i used the
same database that used by others application. Even more, i have 32 layers
that contain about 150 attributes for each. I dont think i have a lot of
time to insert new data into these new column.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I have not gotten it to work with anything but integers.
> Can you add another column with sequential integers to both data sources?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> anakando skrev:
>> Thanks for suggestion. I afraid i cannot change id data type to integer
>> since
>> it contains both of integer and char such as 'FLAG 010'..i just wondering
>> if
>> this is related to the space between 'FLAG' and '010'??
>> Try linking the tables with integer columns, that is usually the only
>> stable solution.
>> anakando skrev:
>>> Yes..my MG version is 2.0.1..Here is my situation. I have database that
>>> contain 2 tables (as example). Both of tables are linked to SDF file
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19451532.html
