[mapguide-users] failling to connect to postgreGIS
Gabriele Monfardini gabrimonfa at gmail.com
Mon Sep 15 03:32:51 EDT 2008
ogc_fid should be put as an integer primary key column in the table
you want to connect to.
See also http://www.gdal.org/ogr/drv_pg.html
Btw, this resolves some issues on selecting elements (with ogc_fid,
selected items are marked in blue, without ogc_fid, no) but I don't
think adding ogc_fid field can do much if you have connection
problems.
Gabriele
On Sat, Sep 13, 2008 at 19:14, andreas mutota <amutota2002 at yahoo.com> wrote:
> Hi all, from where do I get the "ogc_fid" column key and to put it?
> Thank in advance.
>>Andreas
>>You have to have an "ogc_fid" column key.
>>Martin F
> andreas mutota a écrit :
>> Hi there, I am trying to connect mapguide to postgres database. I have
>> moved PostGISMessage.dll,PostGISOverrides.dll and PostGISProvider.dll to
>>  C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO. Also have added
>>  <FeatureProvider>
>>     <Name>OSGeo.PostGIS.3.2</Name>
>>     <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>>     <Description>FDO Provider for PostGIS</Description>
>>     <IsManaged>False</IsManaged>
>>     <Version>3.2.0.0</Version>
>>     <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>>     <LibraryPath>C:\Program
>> Files\MapGuideOpenSource\Server\Bin\FDO\PostGISProvider.dll</LibraryPath>
>>   </FeatureProvider>
>> to privider.xml still I can  not get access to fill in property values
>> for connection to the db.
>> Anyone has an idea of what I can do , please help.
>> Best regards and many thanks in advance.
>> Andreas mutota.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
