[mapguide-users] Points not in correct place??
Love, Bev (Capita Symonds) Bev.Love at capita.co.uk
Mon Sep 15 10:01:23 EDT 2008
Hi all,
I'm hoping this might be a simple problem to fix...
I've been using Autodesk MapGuide 6.5 for the past couple of years and
have had no real major issue with it, but am now looking at moving over
to Open Source MapGuide.
I'm busy playing around with Open Source MapGuide and am creating maps,
with the same shape files that I used with MapGuide 6.5.
I've created several layers which displays lines representing the roads
in the county. I've then created another layer displaying points for all
the towns in the county. I've also created another layer containing
Ordnance Survey raster images. Straight forward and no problems.
However, when I get all the layers on the same map, the points are
slightly out and not displaying in the right place. The road layers and
raster image layers, correctly match up but the point layer doesn't.
Is there some way that I can set the central point for a layer, or has
anyone come across this before??
I've created the layers using MapGuide Maestro.
Thanks in advance!!!
Bev
This email and any attachment are intended solely for the addressee, are strictly confidential and may be legally privileged. If you are not the intended recipient any reading, dissemination, copying or any other use or reliance is prohibited. If you have received this email in error please notify the sender immediately by email and then permanently delete the email. Copyright reserved.
All communications, incoming and outgoing, may be recorded and are monitored for legitimate business purposes.
The security and reliability of email transmission cannot be guaranteed. It is the recipient’s responsibility to scan this e-mail and any attachment for the presence of viruses.
The Capita Group plc and its subsidiaries (“Capita”) exclude all liability for any loss or damage whatsoever arising or resulting from the receipt, use or transmission of this email.
Any views or opinions expressed in this email are those of the author only.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080915/e1b83017/attachment.html
