[mapguide-users] MS SQL and SDF Join Problem
Bruce Dechant
bruce.dechant at autodesk.com
Wed Sep 17 17:26:22 EDT 2008
So just to clarify:
You are joining:
SDF - Primary
MS SQL - Secondary
Inner join 1 to 1
When join key has a space as in "ID 001" you only get 1st record of join, but if you change it to "ID001" then it works.
Have you created a MapGuide trac ticket for this (bug tracker)? http://trac.osgeo.org/mapguide/
I would like to follow up with this as I am working on some performance tuning for the join engine.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of anakando
Sent: Monday, September 15, 2008 8:24 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MS SQL and SDF Join Problem
This is the last week before my presentation about the capablity of MGOS to
my client. This is the only issue that i stucked on,at least for now.
Unfortunately i stucked on the very basic but important task! So if anyone's
of you really have some time to spend to figure out my problem, i really
appreciate it. TQ
View this message in context: http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19504266.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
