[mapguide-users] query question
anakando anakando at yahoo.com
Wed Sep 17 20:56:14 EDT 2008
Hi guys. I am facing this problem too. Did you solved this problem yet?
atorres wrote:
> hi all!
> i have exactly the same problem! how can we fix that?
> thanks in advance
> antónio torres
> David Nuell wrote:
>> My query script is the exact same as the
>> /phpviewersample/query/querymain.php
>> When I create a new command, I copy exactly what the sheboygan layout has
>> as a query command into my own layout.  The query comes up fine, but it
>> never shows any results regarless of what query I run (numbers or
>> letters).  Any help is greatly appreciated.
>> David Nuell wrote:
>>> Hi Listers -
>>> I am having some troubles with a query function and I hope that someone
>>> out there can help.
>>> - have a map built via MapGuide Studio
>>> - have created a new command called 'Query'
>>> - enter the exact same information into the settings of the query
>>> command as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
>>> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
>>> - select the query command and it opens in the side window (right pane)
>>> - I can select a layer that is in my layers list along with everything
>>> else to query the data including the output property.
>>> As soon as I hit execute, nothing shows up.  I have the Sheboygan data
>>> installed and I tried to execute a query there too... but same result.
>>> Nothing shows up in the results panel.
>>> What am I missing?  I suppose it has something to do with the install
>>> since the sheboygan query does not work either.  Any ideas?
>>> Thanks (again).
View this message in context: http://www.nabble.com/query-question-tp16993307p19544112.html
