[mapguide-users] Themed layer works with Mge2008 and not in Mg 1.1.0
Manoj manoj at deltacadd.com
Fri Sep 19 09:54:18 EDT 2008
Hi Jackie,
Thanks Jackie! It works great.
Regards,
MacNair
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Thursday, September 18, 2008 5:20 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Themed layer works with Mge2008 and not in Mg
1.1.0
MGE 2008, whose OS equivalent version is 1.2.0 had some new feature join
capabilities and improvements that may not have existed in 1.1.0 of the OS
version.
- Jackie
MacNair wrote:
> Hi,
> We have a SDF layer, themed based on string values in a field (viz.
> "Status") from SQL Server table. The primary key field in the same table
> (viz "FNo") is also an attribute that is used to join the features in SDF
> layer and the corresponding record in the database table.
> The application works fine with Mapguide Enterprise 2008 showing the
> themed SDF layer. But when the package is loaded on Mapguide 1.1.0, the
> themed layers don't show up.
> Is this case of a silly mistake?  Or was this issue discussed earlier? We
> don't see any threads discussing this though.
> Any help is appreaciated.
> Thanks!
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context:
http://www.nabble.com/Themed-layer-works-with-Mge2008-and-not-in-Mg-1.1.0-tp
19511903p19551030.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
