[mapguide-users] Still tortured by lack of coordinate systems-
on windows this time
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Sep 22 07:57:27 EDT 2008
The "last resort" (that is before actually building and debugging
mapguide) is to use "ProcessMonitor":
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
Using this tool you can monitor any file and/or registry access on your
machine.
Restart MapGuide, then fire up the tool.
Use the MapAgent to try to read the coordinate systems.
Once you get the broken results, go back to process monitor, and stop
the monitor.
It will have many unwanted entries.
Find mgserver.exe, right click it, and choose "include mgserver.exe".
You now have all the stuff that MapGuide does when loading.
Now try to filter the "Result" column, by exluding "SUCCESS" results.
After some digging you should be able to see a "categories.txt" that
returns a "file not found".
Once located, you can place the categories.txt file in this location,
and restart MapGuide.
If you report your findings, this bug can hopefully be fixed for future
releases.
Regards, Kenneth Skovhede, GEOGRAF A/S
Joanne Cook skrev:
> Hi All,
> In an attempt to figure out why I can't fix the lack of coordinate systems error, I installed the latest windows version of mapguide open source on my win XP machine. And, ha, ha, I have the same issues as before, namely that I can only see the arbitrary X-Y coordinate systems.
> My experiences seem slightly different to what I find out when I do a search- namely that my environment variables (and registry entries) for GDAL_DATA and PROJ_LIB are pointed at the nad and data files in C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www rather than C:\Program Files\MapGuideOpenSource2.0\Server\Bin
> I have moved categories.txt into the nad and data files in both webserverextensions\www and server\bin, and still have the same problem- no access to the coordinate systems other than arbitrary X-Y in either mapagent or maestro. I have also uninstalled maestro, cleared out all the registry entries relating to it, and reinstalled it, and still no result.
> If someone can help me out I'd be extremely grateful, as if I can't get this fixed I'll have to ditch mapguide and waste the several years I've been battling away with it!
> Thanks
> Jo
> Joanne Cook
> Senior IT Support and Development
> Oxford Archaeology (North)
> 01524 880212
> http://thehumanjourney.net
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
