[mapguide-users] Re: MapGuide Open Source 2.0.2 released
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Sep 24 05:03:19 EDT 2008
You should also be aware that raster reprojection is not supported in
MapGuide yet:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
So, WMS will not work if your map does not have the exact same
coordinate system.
As of MapGuide OS 2.0, you can supply coordinate system overrides on all
featuresources.
Using a tool such as Maestro or MapGuide Studio, you can easily set the
correct coordinate system.
(This won't work if the coordinate systems are not value compatible)
Vector data should convert fine between most coordinate systems.
If you are hitting the default SRID as Zac notes, it is probably because
MG EP uses Mentor,
and MG OS uses PROJ.4 for now:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
As for stability, MGOS 2.0.2 is just out, and reportedly much more stable.
As for MG EP, you will have to ask on ADN, as that is purely an Autodesk
issue.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> Are you using oracle? EPSG:4019 is the defacto fall back when Mapguide
> doesn't recognise
> the SRID with oracle....
> On Wed, Sep 24, 2008 at 4:30 PM, Francisco Javier Rojas Durán
> <francisco.rojas at dasoft.com.mx> wrote:
>> Hi Tom and Zac
>> Since I have tested MGOS 2.0.2, I notice that for my data set there is still
>> the defect with coordinate systems using WMS Feature Sources, which is
>> described better on this post :
>> http://www.nabble.com/WMS---coordinate-system-overriding-in-MGOS-2.0.1-fails
>> -td17665380.html#a17665380
>> So maybe for Zac , and other guys not using several WMS as Raster Feature
>> Sources, should be more reliable the latest release than the previous ones.
>> But why MGOS 2.0.2 does not contains a fix for Ticket 600 ->
>> http://trac.osgeo.org/mapguide/ticket/600
>> I notice that with MGEnt 2009 there is no problem for conversion (but there
>> is another drawbacks) , I have a map with all layers based on LL / WSG 84
>> EPSG:4326, and the message error that appears on MGOS Error.log is:
>> The coordinate system (EPSG:4326) of layer XXXXXXXXXXX cannot be different
>> than the coordinate system (EPSG:4019) of the map.
>> The question is why, if there is virtually no Coordinate System Conversion,
>> since all my data is based on that projection.
>> Since MGEnt 2009 is based on MG 2.0.0.x and not on MGOS 2.0.1 and so on,
>> when either a Service Pack for MGEnt 2009 will be available OR when a MGOS
>> fix for the ticket #600 should be released, since because this issue and
>> other ones (like the described on this post by Andy Morsell using MGOS 2.0.1
>> http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html that still
>> applies to MGEnt) I can't go on production environment for my web app based
>> on MG technology either Open Source or Autodesk.
>> Regards
>> Francisco Javier Rojas Duran
>> Date: Tue, 23 Sep 2008 11:57:16 +1000
>> From: "Zac Spitzer" <zac.spitzer at gmail.com>
>> Subject: Re: [mapguide-users] MapGuide Open Source 2.0.2 released
>> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
>> Message-ID:
>>        <7a85053e0809221857v7f920e6dqf6a8630c19c0dff6 at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> This release is really stable, I did some testing on the original test
>> build and I managed to
>> produce 30,000 tiles without a single error using managed SDF's.
>> a big thanks to the development team for their effort on this one :)
>> z
>> On Tue, Sep 23, 2008 at 7:38 AM, Tom Fukushima
>> <tom.fukushima at autodesk.com> wrote:
>>> The MapGuide Open Source project team is pleased to make MapGuide Open
>>> Source 2.0.2 available. This release contains support for Firefox 3, bug
>>> fixes, rendering fixes and updated FDO DLLs. For the complete list of
>> fixes
>>> please see the release notes:
>>> http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes.
>>> The MapGuide team
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080924/98d6a0f7/attachment.html
