[mapguide-users] MGOS2.0.2 bundled installation won't support php
on IIS6
Rock Beans
rockbeans at gmail.com
Fri Sep 26 10:54:35 EDT 2008
This would be the default install of PHP meaning at some point PHP was
installed in the past. Glad it's working. Between the PATH, the (PHP &
FCGI) IIS mappings and the PHP.ini file you should always solve a PHP
issue.
More info on Path and PHP.ini issues. You can find out if your PHP ini
is not working by using PHPINFO code as a test page.
http://trac.osgeo.org/mapguide/ticket/454
On Thu, Sep 25, 2008 at 8:13 PM, brianlee <pengxianghepipi at 163.com> wrote:
> Thanks to Rock Beans
> I make sure the php path is first for the envionment variable named PATH.
> it still won't work.
> Then I check the Application Configuration to found that there are two
> *.php application mappings. The first one points to "C:\php\php.exe", but it
> really does not exist.
> I delete this one and everythings goes ok.
> http://servername/mapguide/phpinfo.php
> http://servername/mapguide/mapadmin/login.php also works.
> thanks again for Rock Beans's tips.
> Rock Beans wrote:
>> This is a loaded question. MapAgent and MapAdmin are completely
>> separate. In Windows environmental variables make sure the PHP path is
>> first for the variable named PATH. Also, create a txt file name it
>> phpinfo.php, add the phpinfo code and run from browser. Place this
>> file in your mapguide www folder so it is web shared. If it runs then
>> you know PHP is working. Note the config INI path and make sure it is
>> using the INI from the mapguide os php folder.
>> In IIS isapi_MapAgent.dll is for .fcgi files make sure you allow this
>> extension in IIS or allow all for ease of development.
>> In IIS php5isapi.dll is for .php files make sure you allow this
>> extension in IIS or allow all for ease of development. Some times
>> using the php-cgi.exe can fix problems but is more resource intense.
>> Code for phpinfo.php Page:
>> <?php
>> phpinfo();
>> If you want to skip all this just install bundled with Apache on some
>> other port like 8008 and move on.
>> Regards,
>> The Rock
>> On Thu, Sep 25, 2008 at 9:14 AM, brianlee <pengxianghepipi at 163.com> wrote:
>>> Hello,
>>> I installed the MGOS2.0.2 by IIS bundled intallation, php & Asp.net as
>>> well
>>> as Java.
>>> but I did not get the php running on IIS.
>>> I have make sure the web service extension is set as isapi_MapAgent.dll.
>>> Verifying the installation by
>>> http://servername/mapguide/mapagent/mapagent.fcgi?operation=enumerateresources&version=1.0.0&locale=en&resourceid=library://&type=&depth=-1
>>> returns error.
>>> [Invalid repository type.
>>> Invalid repository type. Exception occurred in method
>>> MgResourceIdentifier.CheckType at line 716 in file
>>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
>>> I can not access the admin page as well:
>>> to load the sample data packages.
>>> I can open the site by Autodesk MapGuide Studio 2008, to see there is
>>> nothing in the site.
>>> Is there somebody who can help?
>>> thanks
>>> View this message in context:
>>> http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19670417.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19681031.html
