[mapguide-users] Mapguide Integration
    Greenhough, Jamie
    JamieGreenhough at sierrasystems.com
    Fri Sep 26 11:17:25 EDT 2008
Thanks for the responses.!
Darrin, that was the jump off I needed. We were having issues with cross
site scripting problems. Having the web extensions installed on dev
machines, and using local IIS debugging in visual studio, so far, is
solving most of our issues.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Darrin
Maidlow
Sent: Wednesday, September 24, 2008 5:46 PM
To: 'MapGuide Users Mail List'
Cc: Sinelnikov, Andrei
Subject: RE: [mapguide-users] Mapguide Integration
Hi Jamie,
I believe I have done something similar to what you're wanting to do.
My application has  a header containing extensive amounts of application
logic which can interact with the mapguide viewer, and server API as
needed.  Here is some javascript that should return what you're looking
for.
                return
document.getElementById("iFrameID").contentWindow.GetMapFrame();
Now depending on where the iframe is located it can get a bit more
tricky.  Putting an iframe within a user control, or another .net
container (master controls, placeholders, panels etc) will prefix the ID
of the iframe with stuff in the rendered HTML.  For example a user
control called MyControl that contains an iframe with an ID of MyIframe
would render out as MyControl_MyIframe.  To work around this, you need
to setup the iframe with a runat="server" tag, and spit out a global
javascript variable that contains MyIframe.ClientID from the codebehind.
The updated javascript would look more like:
                return
document.getElementById(globalVarWithClientID).contentWindow.GetMapFrame
Also - remember that the Mapguide web tier will need to be installed on
local development machines, and the server will need to be referenced
through the local web tier to prevent cross site scripting problems.
Hope that helps.
darrin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Greenhough,
Jamie
Sent: Wednesday, September 24, 2008 12:57 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide Integration
Hello, I hopefully someone can help me out...
I have been struggling to integrate MapGuide into a custom .NET web
based application we are developing.
I setup MapGuide on an external server, the dotnetsamples run great and
the MapGuide server appears to be working ok. Great. All of the dev
examples reference the dotnetviewer relatively
(../mapguide/mapviewernet), I am referencing via
http://mapguideserver/mapguide/mapviewernet.
We are using MapGuide inside of an iframe. Our application consists of
master pages, user controls, and other .net3.5 goodness.
The problem I am facing, is that I don't know how to reference the
viewerAPI outside of the MapGuide frames.
I can use InvokeScript and pass SelectionXML to another page in another
frame. But this is not really what we want to do. We want to use code
outside of the iframe to manipulate the ViewerAPI and MapGuideAPI inside
of the iframe.
Does anyone have experience with manipulating MapGuide from outside of
an iframe? How about setting up a robust web application with MapGuide
in the middle?
Thanks for reading, looking for direction,
Jamie Greenhough
----Notice Regarding Confidentiality----
This email, including any and all attachments, (this "Email") is
intended only for the party to whom it is addressed and may contain
information that is confidential or privileged. Sierra Systems Group
Inc. and its affiliates accept no responsibility for any loss or damage
suffered by any person resulting from any unauthorized use of or
reliance upon this Email. If you are not the intended recipient, you are
hereby notified that any dissemination, copying or other use of this
Email is prohibited. Please notify us of the error in communication by
return email and destroy all copies of this Email. Thank you.
This email, including any and all attachments, (this "Email") is intended only for the party to whom it is addressed and may contain information that is confidential or privileged.  Sierra Systems Group Inc. and its affiliates accept no responsibility for any loss or damage suffered by any person resulting from any unauthorized use of or reliance upon this Email.  If you are not the intended recipient, you are hereby notified that any dissemination, copying or other use of this Email is prohibited.  Please notify us of the error in communication by return email and destroy all copies of this Email.  Thank you.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080926/0b50060b/attachment.html
