[mapguide-users] MGOS2.0.2 bundled installation won'tsupportphp
on IIS6
Crispin at 1Spatial
Crispin.Hoult at 1Spatial.com
Tue Sep 30 11:41:45 EDT 2008
Ed,
Sorry, can't help as I never had that message (apart from an old MG Studio
incompatability)... back to you, a quick search for "cannot establish
connection" in the nabble newsgroups should keep you busy.
Initially, check all your services are running, reboot, etc!
If you are on XP ensure you have run the increase IIS connections hack from
Andys old post here:
http://www.nabble.com/Windows-Operating-System-to3753177.html#a3756701
Crispin
Crispin
That worked. I no longer get the 500 error. However when I enter the default
admin pswd, I get "cannot establish connection" in the site admin dialog.
Ed Jobe
----- Original Message ----
From: "Crispin @ 1Spatial" <Crispin.Hoult at 1Spatial.com>
To: mapguide-users at lists.osgeo.org
Sent: Monday, September 29, 2008 12:10:10 PM
Subject: RE: [mapguide-users] MGOS2.0.2 bundled installation won'tsupportphp
on IIS6
Folks,
File should be attached and here are our 1Spatial internal notes for getting
the PHP login page to work:
Crispin
*) Edit the PHP.ini file in "C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\Php"
Find the section for "Windows Extensions" and add in the two extension
entries as per below. There will also be a "php_MapGuideApi.dll" at the
bottom of the list, comment that one out with a ";"
I once tried putting the php_MapGuideApiEnvConfig.dll entry at the bottom of
the list and something didn't work so I recommend putting both entries at
the top of the extensions.
*) Restart IIS
;Windows Extensions
;Note that ODBC support is built in, so no dll is needed for it.
extension=php_MapGuideApiEnvConfig.dll
extension=php_MapGuideApi.dll
View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19744698.html
