[mapguide-users] MGOS2.0.2 bundled installation won't support php on IIS6
JeffJensen jefferyjjensen at gmail.com
Tue Sep 30 17:38:27 EDT 2008
Hello,
Following the suggestion from Andy Morsell, I uninstalled and installed the
MapGuide Web Extensions for MGOS 2.0.2 using the Apache Webserver and PHP.
Success! I can now login to Site Administrator.
Only thing I did different on the install was to use the default localhost
IP address (127.0.0.1). So now I'm trying to find where I change it to my
WAN IP address for the MapGuide Server.
Thanks for the help,
Jeff Jensen
JeffJensen wrote:
> Hello,
> I'm unable to connect to the Site Administrator when using a new installed
> MapGuide Open Source 2.0.2. I'm getting the "Cannot establish connection."
> error message.
> I followed the suggestions from Crispin and Jason (see my notes at
> http://faculty.unlv.edu/jensen/html/MapGuide/)
> Any other ideas?
> Jeff Jensen
> Ed Jobe wrote:
>> That was my next move... I've only just started with 2.0.1 and sample
>> data. I was thinking I would just just clean everything up
>> and reinstall 2.0.2 again.
>> Ed Jobe
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19750897.html
