[mapguide-users] MGOS2.0.2 bundled installation won't support php on IIS6
JeffJensen jefferyjjensen at gmail.com
Tue Sep 30 19:12:28 EDT 2008
Hello Ed,
I'm only using the Apache webserver, not IIS. I was getting the same
problems, unable to login to Site Administrator. So it appears the issue
isn't just limited to IIS.
Jeff Jensen
Ed Jobe wrote:
> Are you saying that you installed the option to use Apache, but are still
> using IIS?
> Ed Jobe
> ----- Original Message ----
> From: JeffJensen <jefferyjjensen at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Tuesday, September 30, 2008 2:38:27 PM
> Subject: Re: [mapguide-users] MGOS2.0.2 bundled installation won't support
> php on IIS6
> Hello,
> Following the suggestion from Andy Morsell, I uninstalled and installed
> the
> MapGuide Web Extensions for MGOS 2.0.2 using the Apache Webserver and PHP.
> Success! I can now login to Site Administrator.
> Only thing I did different on the install was to use the default localhost
> IP address (127.0.0.1). So now I'm trying to find where I change it to my
> WAN IP address for the MapGuide Server.
> Thanks for the help,
> Jeff Jensen
> JeffJensen wrote:
>> Hello,
>> I'm unable to connect to the Site Administrator when using a new
>> installed
>> MapGuide Open Source 2.0.2. I'm getting the "Cannot establish
>> connection."
>> error message.
>> I followed the suggestions from Crispin and Jason (see my notes at
>> http://faculty.unlv.edu/jensen/html/MapGuide/)
>> Any other ideas?
>> Jeff Jensen
>> Ed Jobe wrote:
>>> That was my next move... I've only just started with 2.0.1 and sample
>>> data. I was thinking I would just just clean everything up
>>> and reinstall 2.0.2 again.
>>> Ed Jobe
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19750897.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19751176.html
