[mapguide-users] Mapguide without Apache
alucas alucas at svl.es
Wed Apr 1 10:12:19 EDT 2009
Hello,
Yes, you can but you need to do some steps.
1. Modify www/WEB-INF/web.xml to add cgi support:
<servlet>
                  <servlet-name>cgi</servlet-name>
                  <servlet-class>org.apache.catalina.servlets.CGIServlet</servlet-class>
                  <init-param>
		            <param-name>debug</param-name>
                    <param-value>6</param-value>
                  </init-param>
                  <init-param>
                    <param-name>cgiPathPrefix</param-name>
                    <param-value></param-value>
                  </init-param>
                  <init-param>
                    <param-name>executable</param-name>
                  </init-param>
                  <!--Nota: si no le paso las variables de entorno intenta descargarse el resultado de la ejecución del programa -->
                  <init-param>
                    <param-name>passShellEnvironment</param-name>
                    <param-value>true</param-value>
                  </init-param>
                  <load-on-startup>5</load-on-startup>
                </servlet>
                <servlet-mapping>
                  <url-pattern>*.fcgi</url-pattern>
                </servlet-mapping>
2. rename www/mapagent.fcgi to mapagent.fcgi2
3. make a copy of maagent.exe to mapagent.fcgi
4. rename to jar servlet-api
Hope this helps.
Hi all, it is posible use Mapguide without Apache, only with Tomcat?. We are
triying but don´t see the map, only the rest of controls.
Thanks.
# michogar
# Analista Programador SIG
# GNU/Linux Counter 462666
Una visión personal:
http://michogar.blogspot.com
El dia a dia:
http://twitter.com/michogar
"Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
peor... Si lo reproduces del derecho... ¡Se instala!."
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
you play it right ... It installs!.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Mapguide-without-Apache-tp2568654p2569222.html
