[mapguide-users] Rendering defect?
Dave Wilson
dave.wilson at autodesk.com
Wed Apr 1 11:52:21 EDT 2009
To clarify,
Are you saying that around the borders of the frame an edge is generated for the polygon even though the polygon extends past the visible region of the frame suggesting to the user that the polygon is completely visible when it's actually not?
I would argue this is a design deficiency, but that is how it was implemented.
I would log an enhancement trac ticket asking that polygons not be clipped by the map frame.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andreas Morf
Sent: Wednesday, April 01, 2009 9:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Rendering defect?
There is a strange behaviour of MGOS 2.0.2 when rendering polygons with a
<CompositeTypeStyle>: clipped edges of the polygons (which may be borders of the map in a fusion-viewers) are also drawn according the instructions in the <LineUsage> of the <SimpleSymbolDefinition>.
In my opinion this is not a correct behavior of the rendering service!
Attached there is a small sample rendered image.
Is this a case for a ticket?
Any comments?
