[mapguide-users] Modify layout information with code
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Apr 2 02:55:57 EDT 2009
The MapGuide API only exposes the WebLayout and MapDefinition as Xml, so
you basically
have to read the xml (using GetResourceContent) and write it back (using
SetResource).
I have made an API for dealing with this in .Net, and an example can be
found here:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
If you choose to go for the raw Xml approach, you can probably see what
the xml tags are called from the above code.
Regards, Kenneth Skovhede, GEOGRAF A/S
patxmay skrev:
> Hi,
> If anonymous, are you trying to modify a resource in the weblayout in the site repository or the session repository?
> For example i have one layout and many map; i want change the resource map of the weblayout with .net or php code.
> Thanks
