[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Apr 2 02:58:05 EDT 2009
Perhaps the problem is that you are in a "wrong" session somehow?
Instead of connecting to a session, you are creating one?
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Sorry, number line 65
> Hi,
> Effectifly i have send bad tests. Sorry !!
> You can see the new files here : http://patxi.mayol.free.fr/test_before.xml and http://patxi.mayol.free.fr/test_after.xml
> So I do another test in my aspx file : http://patxi.mayol.free.fr/sample4.asp
> With defaultUser="Anonymous" and defaultPassword="" :
> *If I comment the line 69 (webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)) I have this message : 'Unauthorized access.'
> *If I uncomment the same line I have this mesage : 'Permission denied to resource: Session:bfba102a-ffff-ffff-8000-0016d44491c1_en_7F0000010AFC0AFB0AFA//Map_40312.MapDefinition'
> With defaultUser="Administrator" and defaultPassword="admin" : (default value of MapguideOSE administrator)
> *If I comment the line 69 : 'An exception occurred in DB XML component. Error: XML Indexer: Fatal Parse error in document at line, 1, char 1. Parser message: Invalid document structure '
> *If I uncomment the same line I have the same message error mesage.
> It seems there is perhaps a problem with the right authorization ant the method I use to init siteconnection ?
> Perhaps this new information is interesting for you ?
> Regards,
> Francis
> Not sure why, but both of those files have the UTF-8 BOM header :(.
> euskalmap skrev:
>> Hi,
>> Yes, the browser can read the xml file : i have generate 2 files : one just after reading the doc ( http://patxi.mayol.free.fr/test_before.xml ) and another one after modify the Map id ( http://patxi.mayol.free.fr/test_after.xml ) : the 2 files an be reading in my browser .
>> You can see my code here : http://patxi.mayol.free.fr/sample3.asp
>> regards
>> Even if you don't have any xsd files in c:\temp, you should be able to
>> open the xml document using Internet Explorer (just drag it into it).
>> Have you tried to not change the xml, and just save it back to MapGuide
>> after reading it?
>> (In your code, just comment out the part that writes the new Map id into
>> the xml.)
>> euskalmap skrev:
>>> HI,
>>> Yes i have the file WebLayout-1.0.0.xsd in the directory C:\Program Files\MapGuideOpenSource2.0\Server\Schema\.
>>> which method you want that I use to save the weblayout ?
>>> If i save the weblayout in my code with the instruction ,
>>> FileStream fs = File.Create("c:\\temp\\test.xml");
>>> fs.Write(encodedBytes, 0, encodedBytes.Length);
>>> it is normal that i can not read the weblayout because the file WebLayout-1.0.0.xsd is not present in c:\temp directory.
>>> I have not understand how saving and reading the weblayout ?
>>> Other question : Perhaps my mapguide server is not correctly parameterized?
>>> Thanks for your lelp.
>>> Yes, it is very strange that it happens with only weblayouts.
>>> Do you have the file:
>>> C:\Program Files\MapGuideOpenSource2.0\Server\Schema\WebLayout-1.0.0.xsd
>>> Can you save the weblayout if you just read it, and then save it? (eg.
>>> not changing anything).
>>> euskalmap skrev:
>>>> Hi,
>>>> I have try your maestro class in my sample like this :
>>>> http://patxi.mayol.free.fr/sample2.asp
>>>> I have always the same error.
>>>> In the mapguide log file it say 'An exception occurred in the XML parser.'
>>>> and at the end i say about an error in
>>>> MgResourceContentManager.ValidateDocument.
>>>> Perhaps, Mapguide server can not find the WebLayout.1.0.0.xsd file ?
>>>> What you think about it?.
>>>> NB:It is very strange that there is no problem with filter in layer and as
>>>> much problem to modify mapdefinition in layout !!!
>>>> Thanks
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090402/548cd544/attachment.html
