[mapguide-users] Modify mapdefinition in a layout
alucas alucas at svl.es
Thu Apr 2 03:48:43 EDT 2009
Sorry, thisn sample has 3 maps and there is a tool in the toolbar to change the map.
Hope this help.
can you test this sample?
http://www.svl.es/mapguide2009/medioambiente/index.php
If this is what you want to do, I can send you my source code in PHP.
regards.
Hi
I provide the end user with a link to my special page (see the code1). In that page i redirect to the MapGuide viewer files (Response.Redirect).
code1:
The fonction SetLayout Map modify the mapdefinition in my layout. See image here :
The problem : the layout is not modify and i have this message : An exception occurred in the XML parser.
Have you an idea ?
Thanks
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2573862.html
