[mapguide-users] Mapguide without Apache
Zac Spitzer
zac.spitzer at gmail.com
Thu Apr 2 05:21:27 EDT 2009
how about dropping this onto the wiki?
2009/4/2 Micho Gar <michogar at gmail.com>:
> Muchas gracias, alucas.
> Voy a intentar montarlo y ya te comentaré.
> 2009/4/1 alucas <alucas at svl.es>
>> I'm working with eclipse as Development environmet in my local machine.
>> Every developer has his own webserver extensions installed and configure an
>> eclipse server project pointing to the mapguide tomcat installation. The
>> database and mapserver service are installed in another server. This way,
>> every developer executes his own application copy on his local tomcat and
>> you can integrate svn (or another). Something like this is the configuration
>> are you searching for?
>> Regards.
>> Hi all, it is posible use Mapguide without Apache, only with Tomcat?. We
>> are
>> triying but don´t see the map, only the rest of controls.
>> Thanks.
>> # michogar
>> # Analista Programador SIG
>> # GNU/Linux Counter 462666
>> Una visión personal:
>> http://michogar.blogspot.com
>> El dia a dia:
>> http://twitter.com/michogar
>> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
>> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
>> peor... Si lo reproduces del derecho... ¡Se instala!."
>> "It has a legend that if you play an original Windows Vista DVD backwards
>> to
>> hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
>> you play it right ... It installs!.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://n2.nabble.com/Mapguide-without-Apache-tp2568654p2569909.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> # michogar
> El dia a dia:
> "It has a legend that if you play an original Windows Vista DVD backwards to
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
