[mapguide-users] Segment or Peice of Line
wordsy
mwordell at gmail.com
Thu Apr 2 19:20:03 EDT 2009
Hey all;
I am hoping someone else has run into this problem and successfully solved it!.....
I am trying to take a multilinestring and split it up into segments specified by distance. My scenario is as such:
I have a set of roads that are shown on a map, this data is imported with shape files generated from engineers. Right now, the app works great. But.. I have a requirement where the user needs to break up a road into segments, each segment has specific attributes (what the road is made of, or what condition the road is in). I have a UI that a user can break up a road into meter sections that they specify and set attributes on it.
Now, the spatial part. As I said before, the data is stored as a MultilineString. I need to almost query the spatial information and get sub select the spatial data from x to y. We use a multilinestring b/c the roads can be curves etc.
I looked into Mapguides library, and it seems they have everything except this.
Any help would be much appreciated. Thanks!
View this message in context: http://n2.nabble.com/Segment-or-Peice-of-Line-tp2578100p2578100.html
