[mapguide-users] Fusion and Themed Layers - usability
Paul Spencer pagameba at gmail.com
Sun Apr 5 17:15:18 EDT 2009
I think Jason's idea of using the bottom end of the scale + 1 would
improve cacheability (?) but in the end it would be ideal if we could
do the same thing with MapGuide that we did with MapServer which is to
generate a strip of images for each layers/scale and a set of css
offsets associated with them.  The image is only generated and loaded
once, providing significant improvements to responsiveness and load
time.
Cheers
Paul
On 5-Apr-09, at 11:59 AM, Tom Fukushima wrote:
> I know that this keeps coming up during discussions I have with
> developers, however because it does not affect the responsiveness of
> the viewer---that is, you can start using the viewer before the
> legend images are all downloaded, fixing this for performance
> reasons has taken a lower priority.
> If you don't want the images to download, you could set all the
> layers ShowInLegend property to false.
> Off the top of my head, my suggestion for resolving this, is to
> allow the map author to create the custom strip, store it somewhere
> accessible by the web tier (perhaps as resource data or on disk),
> and then allow it to be specified from the Map.
> Tom
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org
> ] On Behalf Of Jason Birch
> Sent: Friday, April 03, 2009 4:04 PM
> To: mapguide-users at lists.osgeo.org
> Cc: fusion-dev at lists.osgeo.org; 'MapGuide at lists.osgeo.org; Internals
> Mail List'
> Subject: RE: [mapguide-users] Fusion and Themed Layers - usability
> Heh,
> Yeah, I can see how that would be unmanageable.  I wouldn't be
> surprised if your use case strains fusion to the level that it's not
> workable for the current version or for 2.1.  I'm surprised it works
> with the AJAX viewer, but maybe the viewer has a different strategy
> for managing legend images.
> Ideally, MapGuide would support a GetLegendImageStrip operation that
> Fusion could then use with CSS sprites to reduce (in your case,
> dramatically) the number of requests to the server.  I believe that
> there may be functionality for this in MapServer layer types in
> Fusion 2.0, but I don't think there is in MapGuide.  Bob Bray put in
> a ticket for this functionality a _long_ time ago, but unfortunately
> I don't think any work has been done on it:  http://trac.osgeo.org/mapguide/ticket/22
> I think that there is a partial measure that could be done in Fusion
> to improve the situation somewhat.  Currently, Fusion does a
> reasonable job of caching images; it only requests a new legend
> image once per scale range context switch.  However, the initial
> request is done using the exact current scale.  If the request
> instead used a fixed value within the scale range (bottom + x?) then
> the images could be better cached by the browser.  If MapGuide sent
> cache headers (last modified, based on the layer definition?) this
> would also help.
> Any Fusion or MapGuide devs have thoughts on this?
> Jason
> From: djonio
> Sent: April-03-09 12:47 PM
> Jason,
> I wanted to respond before the weekend so this is just a very brief
> note. Fiddler shows about 8000 of these(I assume a series for each
> LayerDefiniton):
> GET /mapguide/mapagent/mapagent.fcgi?
> OPERATION
> GETLEGENDIMAGE
> &SESSION
> 2f6bfde6
> -0000
> -1000
> -805a
> -001aa01bd46c_en_7F0000010AFC0AFB0AFA
> &VERSION=1.0.0&SCALE=2770.0556443473797&LAYERDEFINITION=Library%3A%2F
> %2FMIA%2FFacilities
> %2FFCLTY3000_7
> .LayerDefinition&THEMECATEGORY=10&TYPE=2&CLIENTAGENT=Fusion%20Viewer
> HTTP/1.1
> And they appear to be 111 byte 16wX16h png images.
> This was "Showing the Legend" and then doing a Zoom. If the Legend
> is not shown I can Pan and Zoom pretty good.
> I can invest a little more time in this next week. I certainly do
> like this fusion layout and appearance and am sure the users will
> to ... but it has to work. Obviously there are alternatives to
> having a pre-built legend but I really wanted to avoid those alts
> from the get-go. I will delve into it all more on Monday. Have a
> good weekend.
> r,
> dennis
> View this message in context: http://n2.nabble.com/Fusion-and-Themed-Layers---usability-tp2580125p2582561.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
