[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Apr 7 03:13:34 EDT 2009
Sorry, I have no more ideas.
I was guessing that there were some security implications
because you had different results, but looking at your code,
I cannot guess what is wrong.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> In my sample (sending in my before post http://patxi.mayol.free.fr/sample4.asp ) I'm creating a session; so i do not understand your remark ?
> Regards, Euskalmap
> Perhaps the problem is that you are in a "wrong" session somehow?
> Instead of connecting to a session, you are creating one?
> euskalmap skrev:
>> Sorry, number line 65
>> Hi,
>> Effectifly i have send bad tests. Sorry !!
>> You can see the new files here : http://patxi.mayol.free.fr/test_before.xml and http://patxi.mayol.free.fr/test_after.xml
>> So I do another test in my aspx file : http://patxi.mayol.free.fr/sample4.asp
>> With defaultUser="Anonymous" and defaultPassword="" :
>> *If I comment the line 69 (webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)) I have this message : 'Unauthorized access.'
>> *If I uncomment the same line I have this mesage : 'Permission denied to resource: Session:bfba102a-ffff-ffff-8000-0016d44491c1_en_7F0000010AFC0AFB0AFA//Map_40312.MapDefinition'
>> With defaultUser="Administrator" and defaultPassword="admin" : (default value of MapguideOSE administrator)
>> *If I comment the line 69 : 'An exception occurred in DB XML component. Error: XML Indexer: Fatal Parse error in document at line, 1, char 1. Parser message: Invalid document structure '
>> *If I uncomment the same line I have the same message error mesage.
>> It seems there is perhaps a problem with the right authorization ant the method I use to init siteconnection ?
>> Perhaps this new information is interesting for you ?
>> Regards,
>> Francis
>> Not sure why, but both of those files have the UTF-8 BOM header :(.
>> euskalmap skrev:
>>> Hi,
>>> Yes, the browser can read the xml file : i have generate 2 files : one just after reading the doc ( http://patxi.mayol.free.fr/test_before.xml ) and another one after modify the Map id ( http://patxi.mayol.free.fr/test_after.xml ) : the 2 files an be reading in my browser .
>>> You can see my code here : http://patxi.mayol.free.fr/sample3.asp
>>> regards
>>> Even if you don't have any xsd files in c:\temp, you should be able to
>>> open the xml document using Internet Explorer (just drag it into it).
>>> Have you tried to not change the xml, and just save it back to MapGuide
>>> after reading it?
>>> (In your code, just comment out the part that writes the new Map id into
>>> the xml.)
>>> euskalmap skrev:
>>>> HI,
>>>> Yes i have the file WebLayout-1.0.0.xsd in the directory C:\Program Files\MapGuideOpenSource2.0\Server\Schema\.
>>>> which method you want that I use to save the weblayout ?
>>>> If i save the weblayout in my code with the instruction ,
>>>> FileStream fs = File.Create("c:\\temp\\test.xml");
>>>> fs.Write(encodedBytes, 0, encodedBytes.Length);
>>>> it is normal that i can not read the weblayout because the file WebLayout-1.0.0.xsd is not present in c:\temp directory.
>>>> I have not understand how saving and reading the weblayout ?
>>>> Other question : Perhaps my mapguide server is not correctly parameterized?
>>>> Thanks for your lelp.
>>>> Yes, it is very strange that it happens with only weblayouts.
>>>> Do you have the file:
>>>> C:\Program Files\MapGuideOpenSource2.0\Server\Schema\WebLayout-1.0.0.xsd
>>>> Can you save the weblayout if you just read it, and then save it? (eg.
>>>> not changing anything).
>>>> euskalmap skrev:
>>>>> Hi,
>>>>> I have try your maestro class in my sample like this :
>>>>> http://patxi.mayol.free.fr/sample2.asp
>>>>> I have always the same error.
>>>>> In the mapguide log file it say 'An exception occurred in the XML parser.'
>>>>> and at the end i say about an error in
>>>>> MgResourceContentManager.ValidateDocument.
>>>>> Perhaps, Mapguide server can not find the WebLayout.1.0.0.xsd file ?
>>>>> What you think about it?.
>>>>> NB:It is very strange that there is no problem with filter in layer and as
>>>>> much problem to modify mapdefinition in layout !!!
>>>>> Thanks
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090407/0ba3d81c/attachment.html
