[mapguide-users] Bookmarking
GordonL gordon.luckett at arrowgeomatics.com
Fri Apr 10 10:10:13 EDT 2009
Hi Mike,
I have added the following to the right-click menu:
  <Item xsi:type="WidgetItemType">
    <Function>Widget</Function>
    <Widget>LinkToView</Widget>
  </Item>
Now I get a javascript error:
Error: 'this.domObj.nnerHTML' s not an object
Line 2
Char 569951
gordon
Yes that looks correct for the <Widget> part, but you also need
something like this to add it to the toolbar:
 <Container xsi:type="UiItemContainerType">
      <Name>Toolbar</Name>
      <Type>Toolbar</Type>
      </Item>
There should be some way for Studio to put that in, but I'm not sure
how.  You probably also need a label or icon for it in the <Widget> element.
Mike
GordonL wrote:
> Thanks Mike,
> here is what Studio 2010 automatically puts in the xml
> <?xml version="1.0" encoding="utf-8"?>
> <WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
>   <Name>LinkToView</Name>
>   <Type>LinkToView</Type>
>   <Location />
>   <Extension />
> </WidgetType>
> does this look correct?
> thanks
> gordon
> I think it is a matter of adding a <Widget> entry for it and an entry in
> the toolbar <Container> in the AppDef.
> Mike
> GordonL wrote:
>> Hi Mike,
>> I am playing with the "Link to View" widget.  What is required to add it to the toolbar?  Is there some documentation for it's use?
>> thanks
>> gordon
>> It does capture map extent/scale and layer state.  It doesn't capture
>> the sessionid since that is likely to expire, it initializes the map
>> from the MapGuide resource ID, rather than mapname and session.
>> Mike
>> GordonL wrote:
>>> Hi Mike,
>>> Does it capture current Map Scale and Layer State?
>>> Also, does it cupture current SESSIONID?
>>> thanks
>>> gordon
>>> Mike Adair wrote:
>>>> Yes there is the LinkToView widget which provides bookmarking.  It
>>>> provides a labeled anchor tag with a link to the current mapview.
>>>> Mike
>>>> Chris Claydon wrote:
>>>>> I think I saw some support for bookmarking go into Fusion 2.0. There are
>>>>> some developers from DM Solutions on this list that may be able to
>>>>> provide more details...
>>>>> -----Original Message-----
>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
>>>>> Sent: Saturday, March 14, 2009 2:56 PM
>>>>> To: mapguide-users at lists.osgeo.org
>>>>> Subject: [mapguide-users] Bookmarking
>>>>> Hi All,
>>>>> I was wondering, has anyone seen a bookmarking tool (either FUSION or
>>>>> Basic
>>>>> Web Layout)?
>>>>> I think there are different ways of doing this.
>>>>> 1. I saw one solution that grabbed the URL of the web layout (including
>>>>> sessionid) but this expires...
>>>>> 2. I thought I could capture the map name, current scale, and the current
>>>>> layer visibility in the session and store to a database..then apply these
>>>>> parameters after the user logs in.
>>>>> 3. I thought I saw a FUSION demo that "save map" would store the map
>>>>> permanently in the repository and just share it to everyone, but does
>>>>> anyone
>>>>> know if this stored the current status (scale and layer visibility
>>>>> status)????
>>>>> The issue I have with all these approaches is that this requires that the
>>>>> web layout is customized to accommodate the passing of these
>>>>> parameters...
>>>>> it would be great if there were URL parameters (GET or POST) that we can
>>>>> pass the scale and layer status to the whole Web Layout (FUSION or
>>>>> BASIC)...
>>>>> any feedback on how anyone worked through this issue would be great.
>>>>> thanks
>>>>> gordon
>>>>    Michael Adair
>>>>    Senior Software Architect
>>>>    DM Solutions Group Inc.
>>>>    Office: (613) 565-5056 x26
>>>>    madair at dmsolutions.ca
>>>>    http://www.dmsolutions.ca
>>>>    http://research.dmsolutions.ca
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
   Michael Adair
View this message in context: http://n2.nabble.com/Bookmarking-tp2479346p2616368.html
