[mapguide-users] [MapGuide OSE FDO Oracle SL-King0.8.5]HolePolygon Type 7 Problem
djonio DJonio at miami-airport.com
Fri Apr 10 11:08:49 EDT 2009
Some language issues here …
Yes, I have used Mapd3d’s export to Oracle and found it unworkable for my needs. I just could not figure out how to control the thing. Plus, as you state, it outputs in 3d. My organization has no use for 3d so it complicated things unnecessarily.
I used to do the export from Map3d and then strip off the Z using the function “TO_2D” as I described. As time has gone on I have developed my own Map3d to Oracle translator and have never looked back. In case you are interested: http://www.topologyframework.blogspot.com/
r,
dennis
View this message in context: http://n2.nabble.com/-MapGuide-OSE-FDO-Oracle-SL-King-0.8.5--Hole-Polygon-Type-7-Problem-tp2604217p2616649.html
