[mapguide-users] FDO 3.4.0 RC 3
Jackie Ng
jumpinjackie at gmail.com
Mon Apr 13 22:15:52 EDT 2009
I don't think so.
1. FDO 3.3.1 was built with Visual C++ 2005
2. FDO 3.4.0 is built with Visual C++ 2008
3. FDO 3.4.0 has newer APIs
Even if you have the required runtime libraries installed, I doubt a 2005-built MapGuide can use 2008-built FDO binaries.
- Jackie
Howdy,
I'm re-installing mapguide and was wondering if mapguide functions with the new FDO 3.4.0 ?
I remember reading somewhere it only runs with 3.3.1 ... should there be any problems with installing the newer fdo ?
Is it as simple as removing the current Bin\FDO directory and replacing it's contents with the new FDO ones? making sure the providers.xml is correct ?
Or is there really no need to be installing the latest up to date FDO and I should just stick to 3.3.1 then add ecw support ?
Or can anyone take me through the steps of how to make sure the FDOs in use are the best for the job.
Cheers.
View this message in context: http://n2.nabble.com/FDO-3.4.0-RC-3-tp2630730p2630855.html
