[mapguide-users] Select points problem
Jamo adam.jamison at portbris.com.au
Wed Apr 15 22:53:27 EDT 2009
Check that the datasource has a X, Y and Z value even if it only requires an X, Y just assign one of the X, Y columns to the Z and retry, had this problem a while ago and this seemed to fix it.
Good luck
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2641684.html
