[mapguide-users] select the location on map
Ivan Milicevic Ivan.Milicevic at supranet.hr
Fri Apr 17 03:16:56 EDT 2009
Hello Susan,
Here is C# code for selection, it's pretty same as PHP.
MgSiteConnection siteConnection = null;
    InitializeWebTier();
    MgUserInformation userInfo = new MgUserInformation(mgSessionId);
    siteConnection = new MgSiteConnection();
    siteConnection.Open(userInfo);
    MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
    MgFeatureService featureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
    MgMap map = new MgMap();
    map.Open(resourceService, "1"); //opening map with name "1"
    MgFeatureQueryOptions queryOptionsObjekti = new
MgFeatureQueryOptions();
    MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
    MgSelection selection = new MgSelection(map);
    //Defining layer and feature source
    MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
    MgResourceIdentifier featureResIdObjekti = new
MgResourceIdentifier("Library://PROJEKTI/" + TIMgisUser +
"/PODACI/OBJEKTI.FeatureSource");
    //Creating feature filter, this is very important step!
    string filter = "ID=" + idO;
    queryOptionsObjekti.SetFilter(filter);
    MgFeatureReader featureReaderObjekti =
featureService.SelectFeatures(featureResIdObjekti, "OBJEKTI",
queryOptionsObjekti);
    selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
    selection.Save(resourceService, "1");
    StringReader stream = new StringReader(selection.ToXml());
    string selectionXml = selection.ToXml();
    featureReaderObjekti.Close();
    map.Save();
    //Here, you call javascript function and pass the selection var
    Response.Write("<script>select('" + selectionXml + "');</script>");
//This is javascript function that set's the selection from code and do
the refresh.
function select(xml)
parent.mapFrame.SetSelectionXML(xml);
parent.mapFrame.ExecuteMapAction(10);
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan
Daniel
Sent: Friday, April 17, 2009 9:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] select the location on map
hi all
        My plat form is mapguide maestro&php.I connect it with mysql.Now
i want to select the corresponding polygon on the map while clicking on
the data in database.In order to display the database table in the
taskpane,i removed the contents of the file "/mapviewerphp/getting
started .php" and wrote my codings.then how to select the polygon?.Any
one know this????Anyone having coding to do this???
please help me
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090417/624b8840/attachment.html
