[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Fri Apr 17 04:47:24 EDT 2009
thank you  ivan...
                       on which file i have to write this coding???  any
idea??
regards
susan
On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic
<Ivan.Milicevic at supranet.hr>wrote:
>  OBJEKTI is layer name and other thing is path to the feature source.
> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> You can copy/paste feature source from mapguide maestro in layer definition
> window.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
> *Sent:* Friday, April 17, 2009 9:45 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] select the location on map
> thank you Ivan
> but  i 'd like to know on which file i want to write this coding??
> In ur coding OBJEKT1  is layer name right?then what is this
> "Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
> thanks and regards
> susan
> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> Ivan.Milicevic at supranet.hr> wrote:
> Hello Susan,
> Here is C# code for selection, it's pretty same as PHP.
> MgSiteConnection siteConnection = null;
>     InitializeWebTier();
>     MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>     siteConnection = new MgSiteConnection();
>     siteConnection.Open(userInfo);
>     MgResourceService resourceService = siteConnection.CreateService(
> MgServiceType.ResourceService) as MgResourceService;
>     MgFeatureService featureService = siteConnection.CreateService(
> MgServiceType.FeatureService) as MgFeatureService;
>     MgMap map = new MgMap();
>     map.Open(resourceService, "1"); //opening map with name „1“
>     MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions
>     MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
>     MgSelection selection = new MgSelection(map);
>     //Defining layer and feature source
>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>     MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier(
>     //Creating feature filter, this is very important step!
>     string filter = "ID=" + idO;
>     queryOptionsObjekti.SetFilter(filter);
>     MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(
> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>     selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
>     selection.Save(resourceService, "1");
>     StringReader stream = new StringReader(selection.ToXml());
>     string selectionXml = selection.ToXml();
>     featureReaderObjekti.Close();
>     map.Save();
>     //Here, you call javascript function and pass the selection var
>     Response.Write("<script>select('" + selectionXml + "');</script>");
> //This is javascript function that set's the selection from code and do the
> refresh.
> function select(xml)
> parent.mapFrame.SetSelectionXML(xml);
> parent.mapFrame.ExecuteMapAction(10);
> *Sent:* Friday, April 17, 2009 9:11 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] select the location on map
> hi all
>         My plat form is mapguide maestro&php.I connect it with mysql.Now i
> want to select the corresponding polygon on the map while clicking on the
> data in database.In order to display the database table in the taskpane,i
> removed the contents of the file "/mapviewerphp/getting started .php" and
> wrote my codings.then how to select the polygon?.Any one know this????Anyone
> having coding to do this???
> please help me
> thanks&regards
>  susan
> mapguide-users mailing list
> thanks&regards
>  susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090417/643b9d14/attachment.html
