[mapguide-users] select the location on map
susan Daniel
daniel.susan6 at gmail.com
Fri Apr 17 05:57:27 EDT 2009
yeah...i know that..
On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic
<Ivan.Milicevic at supranet.hr>wrote:
> Did you know how to create file that display's database table? If you
> don't know that you must find help somewhere else because I'm not a PHP guy.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
> *Sent:* Friday, April 17, 2009 11:42 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] select the location on map
> Hi..
> No i dont have the file that displays database table...Actually iam
> doing this prjct in php.but i know javascript'
> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> Ivan.Milicevic at supranet.hr> wrote:
> Ok, so you have file that display's data from your database table? Or you
> don't have it at all? How familiar are you with javascript?
> *Sent:* Friday, April 17, 2009 11:13 AM
> hi...
> My problem is that..
> I have a database table..Having colums place ,id etc .If i
> selected(clicking) a data in the table the corresponding place(polygon)
> should be displayed(selected) on the map...My map is a polygon map .each
> polygon having unique id.and the same id is present in the db table
> also....Now u got it?any idea please help...
> regards
> susan
> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> I'm not sure that I understand your problem. With this code you can select
> any feature on map. Can you send a little bit more information? I'm clues
> over there.
> *Sent:* Friday, April 17, 2009 10:47 AM
> thank you ivan...
> on which file i have to write this coding??? any
> idea??
> regards
> susan
> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> OBJEKTI is layer name and other thing is path to the feature source.
> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> You can copy/paste feature source from mapguide maestro in layer definition
> window.
> *Sent:* Friday, April 17, 2009 9:45 AM
> thank you Ivan
> but i 'd like to know on which file i want to write this coding??
> In ur coding OBJEKT1 is layer name right?then what is this
> "Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
> thanks and regards
> susan
> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> Hello Susan,
> Here is C# code for selection, it's pretty same as PHP.
> MgSiteConnection siteConnection = null;
> InitializeWebTier();
> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
> siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfo);
> MgResourceService resourceService = siteConnection.CreateService(
> MgServiceType.ResourceService) as MgResourceService;
> MgFeatureService featureService = siteConnection.CreateService(
> MgServiceType.FeatureService) as MgFeatureService;
> MgMap map = new MgMap();
> map.Open(resourceService, "1"); //opening map with name „1“
> MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions
> MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
> MgSelection selection = new MgSelection(map);
> //Defining layer and feature source
> MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
> MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier(
> //Creating feature filter, this is very important step!
> string filter = "ID=" + idO;
> queryOptionsObjekti.SetFilter(filter);
> MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(
> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
> selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
> selection.Save(resourceService, "1");
> StringReader stream = new StringReader(selection.ToXml());
> string selectionXml = selection.ToXml();
> featureReaderObjekti.Close();
> map.Save();
> //Here, you call javascript function and pass the selection var
> Response.Write("<script>select('" + selectionXml + "');</script>");
> //This is javascript function that set's the selection from code and do the
> refresh.
> function select(xml)
> parent.mapFrame.SetSelectionXML(xml);
> parent.mapFrame.ExecuteMapAction(10);
> *Sent:* Friday, April 17, 2009 9:11 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] select the location on map
> hi all
> My plat form is mapguide maestro&php.I connect it with mysql.Now i
> want to select the corresponding polygon on the map while clicking on the
> data in database.In order to display the database table in the taskpane,i
> removed the contents of the file "/mapviewerphp/getting started .php" and
> wrote my codings.then how to select the polygon?.Any one know this????Anyone
> having coding to do this???
> please help me
> thanks®ards
> susan
> mapguide-users mailing list
> thanks®ards
> susan
> thanks®ards
> susan
> thanks®ards
> susan
> thanks®ards
> susan
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090417/b74fe881/attachment.html
