[mapguide-users] Select points problem
Jackie Ng
jumpinjackie at gmail.com
Fri Apr 17 10:51:15 EDT 2009
In Maestro, does this PK show up as the key column? If not have you set it?
- Jackie
Have you defined a primary key for that point table?
- Jackie
Check that the datasource has a X, Y and Z value even if it only requires an X, Y just assign one of the X, Y columns to the Z and retry, had this problem a while ago and this seemed to fix it.
Good luck
I try this:
MDSYS.SDO_GEOMETRY(
2001,
NULL,
MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LATITUDE),
NULL,
NULL)
and this:
MDSYS.SDO_GEOMETRY(
2001,
NULL,
MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LONGITUDE),
NULL,
NULL)
but nothing happens
Yeap, the table has a PK.
I'm using Oracle 9i
My Table:
ARE_COORDENADA is SDO_GEOMETRY type and ARE_CODARE is my PK
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2651148.html
