[mapguide-users] MGE2010 GeometryAdapter.cpp exception
Dave Wilson
dave.wilson at autodesk.com
Tue Apr 21 10:41:03 EDT 2009
This is an issue with the layer definition. The old definition didn't store the label alignment values in single quotes, but as of 2010 it's expecting quotes. It doesn't cause a rendering error, just a log entry. If you use Maestro you can edit the layer definitions and add the quotes.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of zolinko
Sent: Tuesday, April 21, 2009 5:48 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGE2010 GeometryAdapter.cpp exception
Hi there,
We moved to 2010 from 2009 (enterprise), and now we
find "interesting" rows in the mapguide server trace log:
StackTrace:
- MgStylizationUtil.ExceptionTrap() line 202 file .\GeometryAdapter.cpp
<2009-04-21T13:24:27> 2564 Ajax Viewer 10.1.1.78 Administrator
Warning: An exception occurred in FDO component.
The identifier 'Halfline' was not recognized.
Is it true, that in the version 2010 the 'Halfline' verticalalignment
value is not supported (and in 2009 it was)? I don't think so...
What can be the problem?
Tia,
Zoli...
View this message in context: http://n2.nabble.com/MGE2010-GeometryAdapter.cpp-exception-tp2669506p2669506.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
