[mapguide-users] Parcel Selection Set written to a file
Jason Birch
Jason.Birch at nanaimo.ca
Tue Apr 21 23:06:16 EDT 2009
Hi Chuck,
I see you're using AJAX, so this won't be of direct use to you, but perhaps some of the concepts will be useful. Flexible web layouts (Fusion) contains SelectRadius (click and drag) and SelectRadiusValue (to pre-set radius for single-click SelectRadius) widgets that do most of what you want.
http://trac.osgeo.org/fusion/browser/trunk/widgets/SelectRadius.js
http://trac.osgeo.org/fusion/browser/trunk/widgets/SelectRadiusValue.js
If you were using Fusion, you could either clone these and hook them up to a back-end script that outputs the CSV, or you could look at creating a custom renderer for the SelectionPanel widget that either somehow generates the CSV itself (not sure how you would do this in JS) or links to a custom back-end script that generates the CSV given a list of IDs or the initial selection parameters.
http://trac.osgeo.org/fusion/wiki/HowToCustomizeSelectionPanel
Jason
________________________________________
Sent: Tuesday, April 21, 2009 7:06 PM
Subject: [mapguide-users] Parcel Selection Set written to a file
I am looking for routine that allows for an easy selection of Parcels by
radius user specified at keyboard or as tooltip while dragging out circle.
The selected parcels are then displayed in a window and then the ability to
write info to a comma delimited file.
Using MGE 09 AJAX
Any help would be appreciated
