[mapguide-users] Mapguide studio with FDO Mysql provider
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Apr 22 02:46:42 EDT 2009
That is how Studio does it. If you change the datasource, it resets your
layer.
You can use Maestro to change the FeatureSource, but you have to
manually check that
your new FeatureSource has all the columns used in the layer setup.
You can also just accept that the layer is reset, and set it up again.
If the layer was non-modified when you began, I suggest you send a bug
report to Autodesk.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> when i create a data connection (named Test_MySQL) like 'OSGEO FDO Provider
> for MySQL' (FDO 3.4) in Mapguide Studio 2.2, i have no problem :
> i edit the IP address of my Debian (Sarge) server (with MySQL server 5), the
> name of bd, the user and password ==> the test connection is success.
> But when i create a layer to this data connection , after choice the
> featuresource 'Library://Ag Base/Donnee/Test_MySQL.FeatureSource', i have
> this message :
> 'You are about to select an incompatible data source. To continue and Re to
> initialize the copy with the default values'
> the control of objects classes as a sign 'Be carreful' and the list of
> objects classes is empty.
> Have you an idea ?
