[mapguide-users] Problem loading raster (TIF) files --- solved!
    padmini godavarthi
    godavarthi.padmini at gmail.com
    Wed Apr 22 04:51:51 EDT 2009
iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
iam using mapguide maestro for creating packages...........
Now i want to load tiff image in my map
How to do it???????
how to generata config file from mapguide
maestro??????????????????????????????
Regards,
Padmini.
Jason Birch wrote:
> Peter,
> If you're generating the config file based on the (outdated?) schema in
> the FDO source, you'll not get the most efficient use of the images.
> There is also a <Bounds> element (or something like that).  Try generating
> a config file from Maestro for an example.
> Jason
> -----Original Message-----
> From: psciga
> Sent: April-22-09 12:29 AM
> Subject: Re: [mapguide-users] Problem loading raster (TIF) files ---
> solved!
> Please have a look on the position lines of my first posting in this
> thread.
> <InsertionPointX>2526500.000</InsertionPointX>
> <InsertionPointX>5718000.000</InsertionPointX>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2674975.html
