[mapguide-users] FDO Provider for Postgis ERROR
nasp
nspitilli at hotmail.com
Wed Apr 22 06:08:47 EDT 2009
Thank you very much for your answer.
That is what I got from Mapagent:
Library://POSTGIS/postgisDB.FeatureSource 2 Administrator
2009-04-17T08:25:15Z 2009-04-17T08:25:15Z true Everyone r,w
So, Mapagent returned no XML. Probably the problem is the Postgis provider,
but how can I solve it?
When I test DataConnection with Maestro, I got "Provider reported no errors"
but in the error log (when I try to create a layer on that data connection)
I find "Error: Cannot establish connection.".
Why?
Naspi
This is what I have in mapguide error log:
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute line 105 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
- MgServerDescribeSchema.DescribeSchemaAsXml line 607 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.DescribeSchema line 564 file
- MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
- MgServerDescribeSchema::ExecuteDescribeSchema() line 173 file
Jackie Ng wrote:
> Go to the mapagent interface:
> http://yourmapguideserver:port/mapguide/mapagent/index.html
> Click "Feature" under "Services API"
> Click "GetSchemas"
> Enter the resource id of the feature source and click "Submit"
> If you get xml content, then click "DescribeSchema" and enter the same
> resource id and enter the name of the schema that was returned by
> GetSchemas, and click "Submit"
> If you get xml content here, then there must be a problem somewhere with
> Maestro because the mapagent (that Maestro is talking to) is reporting
> everything as working fine.
> If you didn't get any xml content with "GetSchemas" or "DescribeSchema"
> then something is wrong on the PostGIS provider side.
> - Jackie
> nasp wrote:
>> Hi,
>> I successfully installe PostGre 8.3.4 with Postgis 1.3.5 on windows
>> Vista. I also have Mapguide 2.0.2.
>> I created a new data connection with Mapguide Maestro that refers to a
>> postgis database. The database has 1 table with 1 colum of type geometry.
>> When I do "Test Connection" with Maestro, I get
>> "The povider reported non errors"
>> Then I created a layer based on that connection and I got the message:
>> Failed to get schema from datasource.[..]
>> The remote server returned an error: (559) MgConnectionFailedException.:
>> Cannot Establish a connection.....ExecuteDescribeSchema.
>> If I try to connect to database via OGR Provider-Postgis and It works
>> fine.
>> Could someone help me, please?
>> Thank you in advance.
>> Naspi
View this message in context: http://n2.nabble.com/FDO-Provider-for-Postgis-ERROR-tp2674319p2675221.html
