[mapguide-users] [ZS1] Re: FDO Provider for Postgis ERROR
nasp nspitilli at hotmail.com
Wed Apr 22 09:12:59 EDT 2009
I don't think that it is correct.
unittest is the database
public is the schema
'unittest' database may have many tables each of one with one or more
columns of type geometry.
I added extra tag with Maestro, editing XML of data connection.
Naspi
Kenneth Skovhede, GEOGRAF A/S wrote:
> I assume that "unittest" is a table, and "DataStore" is the database, is
> this correct?
> If so, I will update Maestro to include the DataStore field.
> How did you add the extra tag, through Maestro or throug the MapAgent?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> nasp skrev:
>> I don't know why Maestri didn't add Datastore tag.
>> I manually added Datastore tag. Data connection test is ok.
>> When I create a layer on that data Connection I get
>> MgInvalidStreamHeaderException
>> Attached to this message you can find the print screen error.
>> Naspi http://n2.nabble.com/file/n2675832/InvalidStreamHeaderException.jpg
>> Bruno Scott wrote:
>>> Yes my test platform is on windows
>>> I don't see your Datastore tag!
>>> This is my connection
>>> <Provider>OSGeo.PostGIS</Provider>
>>>   <Parameter>
>>>     <Name>Username</Name>
>>>     <Value>postgres</Value>
>>>   </Parameter>
>>>   <Parameter>
>>>     <Name>Password</Name>
>>>     <Value>root</Value>
>>>   </Parameter>
>>>   <Parameter>
>>>     <Name>Service</Name>
>>>     <Value>unittest at beaufix:5432</Value>
>>>   </Parameter>
>>>   <Parameter>
>>>     <Name>DataStore</Name>
>>>     <Value>public</Value>
>>>   </Parameter>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/FDO-Provider-for-Postgis-ERROR-tp2674319p2676068.html
