[mapguide-users] MgAuthenticationFailedException raised when
should be caught
Jason Birch
Jason.Birch at nanaimo.ca
Wed Apr 22 11:44:13 EDT 2009
Assuming that you're including constants.php/common.php, the code looks fine. Care to try mine (attached, and works for me on 2.0.2/IIS/PHP)? You may have to adjust the paths to the PHP includes.
FYI, if the user doesn't exist, you'll get a different exception (MgUserNotFoundException). I usually catch the generic MgException and if necessary deal with the type of exception by comparing against get_class($e).
Jason
-----Original Message-----
Sent: April-22-09 6:11 AM
Subject: [mapguide-users] MgAuthenticationFailedException raised when should be caught
I'm getting this error:
Fatal error: Uncaught exception 'mgauthenticationfailedexception' in Unknown
<?php
header("Content-type: text/plain");
require("../mapviewerphp/constants.php");
require("../mapviewerphp/common.php");
try
InitializeWebTier();
$userInfo = new MgUserInformation("Administrator", "fred");
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
catch (MgAuthenticationFailedException $e)
print "Caught Exception Properly\n\n" . get_class($e);
catch (MgException $e)
print "Didn't catch!\n\n" . get_class($e);
