[mapguide-users] New Enterprise Mapguide Samples unable to
download.
Chris Claydon
chris.claydon at autodesk.com
Fri Apr 24 17:02:30 EDT 2009
Fusion 2.0 is supposed to support Google layers simply by adding them to the ApplicationDefinition for the layout. I played with it a bit, but ran into problems and then ran out of time. The Fusion developers are aware of the issues, and I believe they are working on fixes. The samples that show Google overlaid on Fusion take a slightly different approach by modifying the templates and/or using InvokeScript commands to add/remove the Google layers from the underlying OpenLayers map object used by Fusion. It is quite easy to do with a few lines of JavaScript.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Friday, April 24, 2009 2:54 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] New Enterprise Mapguide Samples unable to download.
>From following the discussions here, it had sounded like those who had tried
to get Google Maps layers integrated into flexible layouts did not have full
success. I also installed Fusion 2.0b and had miscellaneous problems so I
reverted back to my most stable 1.0.1 with some manual fixes. I did post
several Trac tickets so I hope those issues will be fixed in the release
version of 2.0. At this point, while I generally enjoy dinking and trying
new things, I simply don't have time to play with some of these upcoming
features until full release versions of Fusion and MGOS and documentation on
the features are made available.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, April 24, 2009 1:29 PM
To: MapGuide Users Mail List
download.
I'm sure Mike, Paul, Chris or someone else that actually knows what they're
talking about will correct me if I'm wrong, but I'm pretty sure that if
you're willing to install Fusion 2.0 on your own, you should be able to make
it work with MapGuide 2.0.2.
Jason
Sent: April-24-09 12:02 PM
download.
The Flexible Web Layouts using Google Maps API is super cool and exactly
what many of us have been waiting for. I'm looking forward to MGOS 2.1
being released in the near future so I can put this type of functionality
into production.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
