[mapguide-users] 2.1 GDAL Rasters - tiles disappearing on map load
cagray colin.gray at 1spatial.com
Mon Apr 27 04:39:12 EDT 2009
I have a web application using the AJAX viewer on MapGuide 2.1. The map is
basically just rasters using the GDAL provider and AGG renderer. The maps
work fine when not using tiles but when I start to use tiles the tiles load
up but once the map is fully rendered all the rasters/tiles disappear! This
seem to start when I installed the latest 2.1 build but since I put it back
to the older 2.1 build the problem is still there. I have tried clearing
tilecache, changing serverconfig.ini tile settings.
Has anyone else seen this before and can suggest any ways to fix it?
Thanks
Colin
View this message in context: http://n2.nabble.com/2.1-GDAL-Rasters---tiles-disappearing-on-map-load-tp2723517p2723517.html
