[mapguide-users] New Enterprise Mapguide Samples unable to download.
Jonathan W jwitcoski at tycotelecom.com
Mon Apr 27 11:21:53 EDT 2009
Getting back to the original post while I also would like to use the whole
new google interface as well...
who runs the mapguide enterprise site?
I emailed Autodesk and they replied back:
Unfortunately, we do not  have any information regarding the maintenance of
the website you were referring to, as it is neither owned nor operated by
Autodesk, Inc.
and
The Website that you refer to
(http://enterprise.mapguide.com/landing/index.php) is not owned by Autodesk,
and therefore, it is not supported by Autodesk. Technical issues regarding
this Website need to be addressed directly to those who maintain the site.
Is this part of the opensource community?
Mike Adair wrote:
> I can't get to it right now but I do have a task on my plate to get
> these issues ironed out in Fusion 2.0, It should be within the next 2
> weeks.
> Mike
> Andy Morsell wrote:
>> Thanks Chris.  I would prefer to go the Google layers overlaid on Fusion
>> route so will explore that further.  I was able to look at the index.html
>> file for the GoogleSlate template on the MapGuide Enterprise demo page
>> and
>> it looks reasonably straight-forward.  I'll have to setup another test
>> environment and give it a whirl when I get a few free cycles.
>> Andy
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
>> Claydon
>> Sent: Friday, April 24, 2009 2:03 PM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] New Enterprise Mapguide Samples unable to
>> download.
>> Fusion 2.0 is supposed to support Google layers simply by adding them to
>> the
>> ApplicationDefinition for the layout. I played with it a bit, but ran
>> into
>> problems and then ran out of time. The Fusion developers are aware of the
>> issues, and I believe they are working on fixes. The samples that show
>> Google overlaid on Fusion take a slightly different approach by modifying
>> the templates and/or using InvokeScript commands to add/remove the Google
>> layers from the underlying OpenLayers map object used by Fusion. It is
>> quite
>> easy to do with a few lines of JavaScript.
>> Chris.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
>> Sent: Friday, April 24, 2009 2:54 PM
>> To: 'MapGuide Users Mail List'
>> download.
>> >From following the discussions here, it had sounded like those who had
>> tried
>> to get Google Maps layers integrated into flexible layouts did not have
>> full
>> success.  I also installed Fusion 2.0b and had miscellaneous problems so
>> I
>> reverted back to my most stable 1.0.1 with some manual fixes.  I did post
>> several Trac tickets so I hope those issues will be fixed in the release
>> version of 2.0.  At this point, while I generally enjoy dinking and
>> trying
>> new things, I simply don't have time to play with some of these upcoming
>> features until full release versions of Fusion and MGOS and documentation
>> on
>> the features are made available.
>> Andy
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>> Sent: Friday, April 24, 2009 1:29 PM
>> download.
>> I'm sure Mike, Paul, Chris or someone else that actually knows what
>> they're
>> talking about will correct me if I'm wrong, but I'm pretty sure that if
>> you're willing to install Fusion 2.0 on your own, you should be able to
>> make
>> it work with MapGuide 2.0.2.
>> Jason
>> From: Andy Morsell
>> Sent: April-24-09 12:02 PM
>> download.
>> The Flexible Web Layouts using Google Maps API is super cool and exactly
>> what many of us have been waiting for.  I'm looking forward to MGOS 2.1
>> being released in the near future so I can put this type of functionality
>> into production.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>    Michael Adair
>    Senior Software Architect
>    DM Solutions Group Inc.
>    Office: (613) 565-5056 x26
>    madair at dmsolutions.ca
>    http://www.dmsolutions.ca
>    http://research.dmsolutions.ca
View this message in context: http://n2.nabble.com/New-Enterprise-Mapguide-Samples-unable-to-download.-tp2693832p2726679.html
