[mapguide-users] Trying to create an ajax search thingo
Jamo
adam.jamison at portbris.com.au
Mon Apr 27 23:44:01 EDT 2009
Cheers Jackie I've fixed it up changed the MgSelection to MgSelectionBase
where needed.
Also changed the
MgSelection thisSel = new MgSelection() to MgSelectionBase thisSel = new
MgSelectionBase(map); which i think has fixed up the issue
Another issue thats got me stunned is this doesn't work......
foreach (MgLayerBase cLayer in cadFeatures.GetLayers())
Response.Write(cLayer.GetClassDefinition().GetProperties().Count);
However at the same point in code this does?
string layerClassName = cLayer.GetFeatureClassName();
string selectionString = cadFeatures.GenerateFilter(cLayer,
layerClassName);
string layerFeatureId = cLayer.GetFeatureSourceId();
MgResourceIdentifier layerFeatureResource = new
MgResourceIdentifier(layerFeatureId);
MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
queryOptions.SetFilter(selectionString);
MgFeatureReader featureReader =
FeatureService.SelectFeatures(layerFeatureResource, layerClassName,
queryOptions);
Response.Write(featureReader.GetClassDefinition().GetProperties().Count);
I'm not too sure on why or how but I'm not too fussed unless this extra
creation of a MgSelection Set will cause twice as much waiting....
Jackie Ng wrote:
> Perhaps you may have used the wrong MgSelection constructor? The API docs
> says that MgSelection() is a dummy constructor.
> - Jackie
View this message in context: http://n2.nabble.com/Trying-to-create-an-ajax-search-thingo-tp2729762p2729958.html
