[mapguide-users] Trying to create an ajax search thingo
    Jamo
    adam.jamison at portbris.com.au
    Tue Apr 28 02:05:05 EDT 2009
Thanks for the heads up!
That makes things a lot neater :)
Hopefully I can make this available for some commenting when I'm all done :)
Also, you may need to double check that you're correctly using the MgMap API
as a result of http://trac.osgeo.org/mapguide/wiki/MapGuideRfc9
- Jackie
View this message in context: http://n2.nabble.com/Trying-to-create-an-ajax-search-thingo-tp2729762p2730760.html
