[ZS1] [mapguide-users] [Maestro] [Mapguide] Raster projection
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Apr 28 16:08:11 EDT 2009
You need MGOS 2.1 (unreleased) or MGE 2010 (requires purchase) for
raster reprojection to be supported.
You may need to specify the raster projection on the raster featuresource:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
You can also override the vector projection in the same way as
described, if that
makes the display correct.
Regards, Kenneth Skovhede, GEOGRAF A/S
Dju skrev:
> Hi,
> I need to know where can i write the projection parameter of a vector image
> to stick on a raster image. The problem i have is that when i load both, the
> vector one is really smaller than the raster one. I'm working with Geomatica
> too, and it does the reprojection for display by itself.
> Thanks for the help!
