You asked if it could be done with php? You may want to use PHP if you like the language or run a linux server? Regards, Kenneth Skovhede, GEOGRAF A/S Dju skrev: > Thanks i'll look at it. But if everything can be done with maestro i don't > see the purpose to code with php? >
