[mapguide-users] Redline Text
Dave Wilson
dave.wilson at autodesk.com
Wed Apr 29 11:09:31 EDT 2009
There is a DeleteResource API command you can use if you know the name of the resource.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Beverage
Sent: Wednesday, April 29, 2009 8:47 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Redline Text
Well I managed to get the code working, and can add text to the map as a
label for a point. But have a bit of an issue as a result.
Because a user maybe adding more than one block of text to the map, I am
creating a unique feature source in the Library for each one (rather than
reusing one, as the buffer code does), but as a result I am now getting
loads of feature sources being created.
Does anyone know of anyway I can delete these feature sources (in code).
What I want to do is remove the layer from the map, and at the same time
delete any feature sources from the library - they all start with the same
word but then have a time stamp on the end to make them unique.
Any help would be really appreciated =)
Thanks,
Bev
Kenneth Skovhede, GEOGRAF A/S wrote:
> If your data has a spare column (or you can add one), simply set the
> Feature Label to use this column, and
> you can update the column data to change the text.
> If you have no spare columns, you can add a new FeatureSource (or table
> in a database) that has a text column.
> Then insert points that correspond to the desired location (pehaps the
> feature centroid), and update text as you like.
> If you are writing this from scratch, take a look at the buffer code, as
> it shows how to add a (temporary) feature source,
> and corresponding layer.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Love, Bev (Capita Symonds) skrev:
>> Afternoon,
>> I'm hoping someone will be able to help me out.
>> I am trying to create some functionality which will allow the user to
>> add text to a layer, something similar to how a user can draw a line
>> on the map.
>> Does anyone know if this is at all possible, and if so does anyone
>> know of any example code out there??
>> Thanks,
>> Bev
>> This email and any attachment are intended solely for the addressee,
>> are strictly confidential and may be legally privileged. If you are
>> not the intended recipient any reading, dissemination, copying or any
>> other use or reliance is prohibited. If you have received this email
>> in error please notify the sender immediately by email and then
>> permanently delete the email. Copyright reserved.
>> All communications, incoming and outgoing, may be recorded and are
>> monitored for legitimate business purposes.
>> The security and reliability of email transmission cannot be
>> guaranteed. It is the recipient's responsibility to scan this e-mail
>> and any attachment for the presence of viruses.
>> The Capita Group plc and its subsidiaries ("Capita") exclude all
>> liability for any loss or damage whatsoever arising or resulting from
>> the receipt, use or transmission of this email.
>> Any views or opinions expressed in this email are those of the author
>> only.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Redline-Text-tp2663424p2740977.html
