[mapguide-users] initial displacement of map content
JC650
jmarvin at redwoodcity.org
Mon Aug 3 17:25:21 EDT 2009
This problem is fixed in MG2010. So if you can upgrade, that would fix it
for you... at least it did for us.
stoff wrote:
> Hi Chris,
> great job! That was exactly the problem ... if I activate the
> propertyctrl, then the displacement does not occur anymore ...
> I use mapguide enterprise 2009 ... Do you have an idea how to
> find the fix? 'Cause I do not need the property panel on the
> weblayout for the "web-dummys" ... cause there will be no
> selection features ...
> Thanks a lot,
> Stoff
> Chris Claydon wrote:
>> This sounds like a defect that I thought had been fixed a long time
>> ago. Which version of the MapGuide web tier are you using?
>> Also, do you have the property panel disabled? I think that was the
>> case when I last saw this issue.
>> Sent from my iPhone
>> On 2009-08-01, at 4:01 PM, "stoff" <mail at effing.org> wrote:
>>> Hi,
>>> I have a displacement of the map within the Ajax-Viewer (a white gap
>>> at the
>>> top of
>>> the map). It happens on initial map visualization and disappears
>>> when the
>>> splitter
>>> between layerctrl and mapframe is moved ...
>>> http://n2.nabble.com/file/n3370781/versatz.jpg
>>> Any hints are welcome ...
>>> Best regards,
>>> Stoff
>>> View this message in context:
>>> http://n2.nabble.com/initial-displacement-of-map-content-tp3370781p3370781.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/initial-displacement-of-map-content-tp3370781p3380537.html
