[mapguide-users] Unable load PostGisProvider on Ubuntu 8.04
Zac Spitzer
zac.spitzer at gmail.com
Mon Aug 3 21:51:20 EDT 2009
try using ldd to list the dependancies of the fdo files
http://linux.about.com/library/cmd/blcmdl1_ldd.htm
z
On Tue, Aug 4, 2009 at 11:49 AM, Takashige<takashige.nakagawa at gmail.com> wrote:
> Hi Jackie,
> Thank you for the reply.
> There's libpq.so.5.1 file in /usr/lib directory, so I added the directory
> to the PATH variable and rebooted the Server.
> But it didn't make difference. The result was the same when I spacified the
> directory in the LD_LIBRARY_PATH.
> Thanks.
> Takashige
> View this message in context: http://n2.nabble.com/Unable-load-PostGisProvider-on-Ubuntu-8.04-tp3376565p3381818.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
