[mapguide-users] Display current mouse coordinates in MapGuide window?
CroNicoRn ah_jid at yahoo.com
Wed Aug 5 02:17:12 EDT 2009
I found this tips and trick on wesite.. can it use on mapguide open source??
You can switch on the dynamic mouse coordinates (in map units) by adding a
key in Registry.
Run RegEdit and into the branch
HKEY_CURRENT_USER\Software\Autodesk\MapGuide Viewer\5.0\Viewer
add a REG_DWORD type key:
DisplayMousePosition
with value of 1
be careful when editing Registry
http://www.myguidepages.com  http://n2.nabble.com/file/u115131/ajid.jpg
View this message in context: http://n2.nabble.com/Display-current-mouse-coordinates-in-MapGuide-window--tp3389452p3389452.html
