[mapguide-users] change selection color in Printable Page
northtron
rnorthcott at gmail.com
Thu Aug 13 08:36:19 EDT 2009
Hello,
I was able to find out how to change the selection color from blue to my
own choice through the
ajaxmappane.templ file. it was easy, and I understood all the changes.. as
documented here:
http://www.jasonbirch.com/nodes/2008/12/02/213/changing-selection-colour-in-mapguide-ajax-viewer/
but, when you select a parcel, then try to load a printable page, the
selected parcel reverts back to the blue selection.
So i decided to go into the printablepage.templ file, and to my surprise,
modifying the req Parameter values in a similar way to the ajaxmappanel
template file, did not yeild the same results. There were no errors to my
changes thrown, but the color was not changed with the modified url
parameters
Does anyone know of a way to change the Selectable color on the printable
Page results? either inherintly, or directly.
Quite the pain, the reason I want the color changed is because the blue is
too dark when printed on a B&W printer. I don't overly care about the map
panel color.
Thank you, any insight would be appreciated.
-Ryan
View this message in context: http://n2.nabble.com/change-selection-color-in-Printable-Page-tp3437645p3437645.html
